1998 75 Force.
Still looking for the cause of the miss at idle.
Removed the reeds to check their condition and noticed what looks like a small tear in the inner gasket between no.1 and no 2 reed blocks. The close-up photo shows a recessed area in the adaptor plate which looks like it would be part of the original design.
Update
Just tore the gasket in the same area between no 2 &3 and there is a similar recess.
The edges of the original tear look dark as if gasses have been transferring between the two crank cases.
A couple of questions.
1. Do you think this tear could be causing the misfire?
2. The reeds look good to me except a couple do not close completely. (0.5 mm approx) Is this OK?
3. Do I need to remove the reed blocks from the adapter plate to clean up and fit a new gaskets.
4. Do the reed blocks have to go back into the adapter in exactly the same positions and orientation?
5. Do I need to use any thread locking compound on the screws?
6. Is there anything else I should be looking out for whilst I have the motor in this state?
Sorry about all the questions but this is all new to me and I value the advice giving by the people on this forum.
Thanks
TwoFish
Update
Thanks
TwoFish
