dingbat
- Nov 20, 2001
- 17,020
Re: Reel spooling question
A spinning rod does not need anywhere near the size guides they put on rods built using the tradtional "cone of flight" method. Take a look at a spinning rod built using the "Concept" method one time. The guides are 1/2 the size and the rod performs considerably better.
The line is under tension when spooled so the size of the guide should have nothing to do with the problem.i think the prob is the size of the guide. spinning and casting rods are two differant animals. you loaded a spin reel with a casting rod.spinreels need the bigger guides .
