Refrigerator Not Working - Advice?
JTDeli
I have just de-winterized my Sea Ray and my fridge won't turn on. My DC and AC systems are powered up.<br /><br />Any one have any ideas? I have the same issue with my icemaker.<br /><br />This may be a coincidence, but there is water in my high-water bilge (located in the cabin). Could have been from drainage, but I am not sure...<br /><br />-J
Bob in Calif.
Re: Refrigerator Not Working - Advice?
Start with the cheap stuff first, like a blown fuse. You mentioned there is a lot of water in your boat. You might have a corroded connection that caused the ground or power wire to fail. <br />If you are trying to start it on 12 volts, try 110 volts. It should respond quicker if the refer. will work at all.<br />There might be a fuse near the electrical connections in the rear of the refer. That's worth checking for also.
knowake
try looking for a loose wire on the back of refrig not hard to pull out most of the time thats whats wrong if it was working befor and just stopped i know it happiend to me
SeaMasterZ@aol.com
are the fridge and the icemaker on the same circuit? could be one or the other is making the circuit breakers trip, taking out the other in the process
