mr geets
- Nov 16, 2012
- 95
My pontoon has an onboard permanent fuel tank which I wanted. Refueling is a real pain if I use a jerry can. The fuel tank neck filler is mounted vertically on the left side rear fence area off the sun platform and I have a heck of a time adding fuel on or off the trailer (I won't refuel on the water if possible) Not sure why a horizontal filler neck is not a feature. Any ideas for easy fuel transfer from a jerry can?.
Just a side note, the 90 Merc efi 4 stroke gets much better fuel economy than I expected. It appears that I can go 95 miles +/- whereas our usual 20 miles in a day is max. After the first fill up (creates a heavy weight in the corner rear) and not using much fuel, I run 1/2 tank unless I am on a big lake or weather condition
