Re: Regal 252
a 5.7 and an alpha package is the bare minimum for a 25 footer.
yes you winn notice a big difference between the b3 and the alpha....
the boat will be harder to control around the docks. and hole will be slower due the single wheel instead of the counter rotating duo.
as far as regal it self....i have built a 3060 that was sunk in salt.....big holes in the hull...
so i got very framilliar with the building procedures and the quality of the boats.....keep in mind that it was an 05 not a 94.
the regal finish of the bot ...including upholstery and hardawre was all mid grade parts....(high end for today standards)
i was very happy with the fit and finish.
the construction was also very good, (reguardless of finding a set of fiberglassing sizzors in the hull !)
the hull was 3/4 inch thick.....the transom and stringers were a compostie material, and very little wood was found in the boat.
even with a massive impact that tore both drives off, and created serious holes in the hull (4) the boat stayed afloat for several hours as the pumps tried to keep up.
an interesting note here.....the cg was called to save the vessel....they tried to fire up thier pumps and tow it to shore....however thier pumps did not work.....so they shut off the boats pumps,,,,,took the passengers aboard the cg vessel and watched her go down !
if the cgs pumps would have worked......the vessel would have been saved....the 4 bilge pumps were just not enough to keep up....but gave 3 hours of life to the strickened craft.
i did a full re fit on the boat......every system....every wire, nut, bolt, drive, motor, gauge, and canvass was re done. this includes the hull damage, gellcoat and bottom paint, gen set air conditioning, galley.
everything that was on the boat was re done
i like regals
