Regarding lower unit oil burnt.
w2much
The motor I am getting ready to go is a 1991 150 Johnson. I went for a spin with the previous owner before purchasing the boat and motor setup. I have previously posted regarding the leaking lower unit . This problem has been resolved. I saw a recent post by Zeltron about his lower unit going bad after rebuild. He stated how it was fried. So before I did my lower unit reseal I of course drained the old grease/ oil from it. There was water in it but upon taking the lower apart all of the bearing seemed to be in good shape. What was odd was the condition of the lubricant. It was actually black and super thick.. I figured that because the boat had sat for so long before we test rode it that the water I saw was new water and that the lubricant was what was left of the old lubricant which we had run with. In the past the lube had leaked out so that we were in fact running with a very low volume. There was almost no rust in the lu. . The only bearing which had any rust I replaced. So now I am wondering what it was I actually saw regarding the tarrish lube. I have been running and shifting the motor at home in a test barrel.
Rustywrench
Are you able to vaccum or pressure test the gearcase for leaks? If it passes that test them pit new lube in & run it for short period of time (hour or so)? Doesn't have to be expensive gear lube for this. Drain & see if it looks any better (flushing). At this point you don't have much to loose. The 150 gearcase is very robust for that horsepower (same as 200/225 except driveshaft). The 1991 took a odd D/S so replacing the gearcase will be a little more expensive if you had to go that way.
w2much
Yes . I was able and did pressure test the lu.Of course before the seal kit it leaked at the seal, a pitted driveshaft. New seal kit in and it held and of course now has fresh LU grease/lube in it. Just waiting for time to take it out and run it. I used the cheap WalMart stuff. Then, yes I will check the lu lube again..
Rustywrench
If it originally had good marine grade lube in it then those lubes can hold up to 25% water in suspension. That might account for your lumps, etc. The dark, burnt appearance could just be that it hasn't been changed in forever. Usually the good lube doesn't burn so bad on a 150, but it should be changed at least every fall before freezing temps (depending on where you live) that way you will see the water before damage can occur. Premium lubes do have there advantages.
w2much
Kind of what I thought.The boat had been stored for quite a while before we took it for a spin. I just never saw lu lube looking like this before.After first seeing it I was expecting a horror show inside the unit. Upon opening then resealing I was surprised that it looked so good inside.
Does the hot exhaust from a motor get near the oil containing part ?-----Exhaust is to be cooled by water.----What if there are issues there.----Refilling of gearcases is a simple job and mistakes have been made.
