rehubing volov long hub props
fire pump
I just had a volvo prop rehubed. The dealer installed the new hub crooked. When I complained they agreed to install a second new hub. To may surprise the same hub,the one installed first, was used a second time. I questioned the dealer about reusing hubs and he said that as long as the newly installed hub was not spun it could be pressed out and then reglued and pressed back in. Can a hub that was glued into a prop be pressed out and reglued and pressed back in.
Ben Konopacky
Re: rehubing volov long hub props
fire pump,Is he(dealer) going to stand behind the re-rehub,and for how long? take his word if he will gurantee it in writing..around here 90 days with no dings on the prop.
f_inscreenname
Next time don't bother to rehub a volvo prop. There is a thousand of them on e-bay for a lot cheaper then I am sure you spent.
fire pump
Thanks, for you reply the rehub only cost <br />$ 45.00.<br /><br />I just wanted to know if I was being ripped off.
