Use your hand it's easy put the rings on the piston and set it down until the ring sits on the block. Then get a popsicle stick or a wooden dowel and just push the ring in the groove,make sure the locating pin is lined up with the ring gap. Put slight pressure on the top of the piston and it will drop in when the ring is in the groove. You will see as you work it around that the piston will drop in the hole slightly holding the ring in the groove.
