Reinstalled Alpha One Drive Shift Cable Hangs
snake91876
Finally got my alpha drive back together and bolted back on boat, i have the shifter in forward when i installed. Once bolts are tight i can shift a few times from drive to neutral to reverse and then it hangs up in forward and binds. I pull drive back slightly and looks like roller is not staying in that spot on the cable. The cable had a blue casing right there that looks broke but cable is not frayed. Do you think it could be sliding out causing the swiveling roller to be pushed out of alignment.
Re: Reinstalled Alpha One Drive Shift Cable Hangs
Ayuh,.......... You shoulda replaced the Cable while you had it apart.......
On those cables, both the Inner,+ Outer casing have a Job to do,.......
So,.....
Your's Needs Replacing.........
snake91876
i will replace the cable i do you think that will solve my problem and do you have an idea on the cost of one.
Don S
I would get the "NEWEST" OEM Merc shift cable. It lists for around $63. But the inner cable is teflon coated and works much easier and lasts a lot longer than the standard SS cable sold by Sierra and older Merc cables.
The Merc number is 865436A02
