Relay/bus box?
bilgsmf
1983 wellcraft v20 came with a 140hp evenrude. I am replacing the 140 with a 150 yamaha OB motor. There is a black box wire relay and the contacts are corroded and i will need to replace, but i cannot determine what its called and cant find diagram of it anywhere. Not sure its a wellcraft or evenrude part? Is someone familiar with this part?
GA_Boater
Welcome aboard.
I see blue and green wires exiting the box, it may be an Evinrude tilt/trim relay box. Where do the wires lead? Got the cover?
dwco5051
As GA-Boater said it is the tilt/trim relays for the Evinrude motor. Not needed for the Yamaha
