Removal of flotation foam
cable guy
I am starting a new project and I need to replace the entire floor from the stringers up.What is the easiest way to remove the flotation foam.I could probably work around it but I am doing a complete restoration.
bigbad4cyl
Re: Removal of flotation foam
a pointed shovel and a clam shovel . it is tiresom work, buy a box of trash bags and hire one of those guys off the corner ...
I Think it was Crabbait that told Me about using a Spadebit, in a cordless Drill..............<br /><br />It'll Chew the stuff Up like No Tomorrow...........<br /><br />Works Great for Digging Out foam that Doesn't have access for the Shovel.........
Chief101
If you have access to a heavy duty weedwacker try it. ;)
Realgun
Best thing is a wire brush for the angle grinder but it makes a mess as in loads of dust. Start with the shovel. :D
