mrsaundep
- Jun 9, 2009
- 55
Engine Make Mercruiser
Model MCM 140
Serial number 5568367
Displacement 181 CID
I am Trying to pull the harmonic balancer off the crankshaft free end to change the leaking oil seal behind. Engine is pulled and in workshop. I have a balancer puller that fits perfectly. Trouble is it wont come off. The puller bolts are now so tight I am scared something will break. The puller main bolt (centre bolt) thread is quite coarse, but the 3 bolts into the hub have a fine thread and I have pulled these up tight after the main centre bolt went so tight that it would not turn any more. I have now tried heat on the balancer hub (not too much, I am scared of affecting the rubber). I have also applied penetrating oil to shaft/hub and down the keyway. It just wont budge. Any ideas please?
Model MCM 140
