Removal of pivot housing
bijou22
Hi, I have removed the sterndrive and now want to change the bellows, having trouble removing pivot.
Does anyone know if you use a spline drive socket to remove the pivot pins. What size?
VP 4.3GL
1997 SX Cobra leg
Don S
Re: Removal of pivot housing
The hinge pin tool will probably be best, but you might be able to use a 1/2" allen wrench. Just cut off a section and use a socket on it.
bijou22
Tried the allen wrench Don, kept slipping all the time. I had to basically hang on the wrench bar to get those pins out using the correct tool. Think they were thread locked also.
Don S
Yep, the yellow stuff is thread locker, the white stuff is corrosion. Plus the torque of 105 ft lbs makes them difficult to get loose at times. Heat helps.
