Remove lower unit to access water pump
trent_tweeter
1977 175 johnson. There are 5 bolts as far as I can see but the l/u will not budge. Shifter linkage is removed as is entire powerhead. Am I missing something? Please help.
Thanks,
Peter
wilde1j
Re: Remove lower unit to access water pump
You got the one under the torque tab plate? You know the power head doesn't have to come off to replace the water pump?
