Lostuzer
- Jul 5, 2007
- 25
18902D ? E12329 ?1969? 18hp Evinrude Fastwin
(Converted to short shaft)
I broke my drive shaft the other day and decided while I was down and partially apart to clean, paint, lube, replace belly pan mount, etc, until I could find a replacement drive shaft I can afford (26 X ? 4 spline and 11 spline).
I?ve always had a problem with the steering being a little too tight for my taste so I thought I might as well tear that part down and clean and re-lube with fresh marine grease.
I removed the thrust washer (plastic ring) and ?O? ring from the bottom of the assembly and the Co-pilot adjustment screw and spring from the upper area.
I at first tried to tap the shaft out with a 24oz. ball peen and a piece of aluminum bar stock as a buffer but as I proceeded the assembly became much tighter. At about an inch of headway I was cringing at the amount of force I had to use.
I then reversed directions using a wooden 2X4 as a buffer. Now, back in it?s normal position, it is no looser or tighter than before.
I then applied heat with a propane torch and tried pulling as I twisted back and forth (no hammer blows this time}. It moved up about an eighth of an inch AND got much tighter as it was displaced.
Could anyone give me the SOP for removing this?
Thanks,
Bob
Thanks,
Bob
