Remove stains from fiberglass
garya0416
What is the best way and cleanner to remove rust and grease stains from fiberglass.
Salty Sal
Re: Remove stains from fiberglass
Greased Lightening degreaser is good<br />for removing acrylic, etc. and I imagine it would<br />be good for removing grease stains.<br />Lime away- If I stand correct, I read that people have used this to remove rust stains.<br />On and Off-This product comes in a white bottle and is used to disolve barnacles and stains. It does remove rust - just don't get it on your trailer because it destroys the galvinization.
KaGee
OXY-CLEAN is real good for those black spots and stains from drain holes.
Terry H
Acetone for the grease, and muriatic acid for the rust...that's what I use...just a thought :)
Sean Riddle
Simple Green for grease and 3M marine fiberglass cleaner wax for the rust stains. This wax has a rubbing compound in it that will take care of those rust and grease stains and leaves a nice shiny wax coat when buffed. Hope this helps, RR
