crazycowboy1972
- Apr 27, 2011
- 2
i just recently purchased a OMC 5.0 cobra and was checking the lower unit out. I removed the plug on the side of the unit you know the one your not supposed too! Well after trying for about an hour to get the plug started back on the threads i believe it has fallen further down the opening inside out of reach. my qeustion is, If i plug this hole could this little nut cause me any serious problems in the future other than possably causing the engine to run hotter?
P.S. This plug is actually a drain for the water pump. it has nothing to do with the shifting or cooling. i was told it was only a drain. but he wasn't sure what would it cause by leaving inside
