iriesh_guitar
- Aug 7, 2013
- 2
How do I get the water pump out of the engine block. I see I have to remove three allen bolts, two hoses, and remove belts. My problem is, there is an iron? bracket that goes between the input and output of the pump. It looks as if the pump will not come out with this bracket in the way and it does not look like it can be moved. Any suggestions.
