Removing bench seats,,,,HOW
Eastexn1
I have a 20’7” Bennington pontoon and am wanting to replace the two front bench seats. How are they secured. I assumed they were screwed from the top thru the seat base to the decking. Not so. They have two screws thru the base, but are still secure with no more screws showing.
Thanks
Lightwin 3
Can you look under the deck to see if you see any additional attaching bolts. Or, is your underdeck covered with flashing like ours?
Eastexn1
I thought about that, but the underside is lined with aluminum sheeting. I can’t imagine they would screw the seats from the underside. I,ve redone two barges and the screws were put in from the top side.
Thanks
