Removing Boat Numbers
sixgun95
Anyone have any tips on how to remove the vinyl boat numbers? Moved and must change them!
UncleWillie
Re: Removing Boat Numbers
A finger nail or a credit card will help to lift an edge.
Just keep pulling Slooooly and evenly.
They should come right off.
It is not as difficult as you might think.
Just take your time, If they keep breaking, you are pulling too fast.
A little heat from a from a Hair Dryer often helps.
JASinIL2006
Mine peeled off pretty easily once I got a corner up and started. A bit of acetone afterwards, to remove any adhesive/crud, and you'll be good to go!
Knot Waiting
Heat gun or hair dryer to help release the adhesive and soften the vinyl. Fingernail or PLASTIC razor blade to lift the edge. Pull and peel away. If there is any residue left behind use "goo gone" to remove it. It's a citrus adhesive remover that wont harm the gel coat.
Note: Sometimes a slightly raised shadow of the graphic stays in the gel coat. There is nothing you can do about this.
spdracr39
hair dryer and patience try to pull them off whole.
eavega
Goof-off did it for me. Got the letters and old registration stickers off the hull in no time at all.
Rgds
fish hook
what they said....... also, pull them slowly at a sharp angle. Keep re-gripping the old sticker close to the base so it wont stretch and break. They should come off fairly clean. If you're removing an old state registration sticker, it will most likely have a backing that separates from the sticker (to avoid transfering them from boat to boat) and is much harder to get off. Using goof off and a plastic scraper multiple times worked for this - with some elbow grease!!
plastic scraper and heat gun. set about 200F
warm the decal, start at a corner and pull back on itself.
a bit of brake clean to remove any left over adhesive, then an alcohol wipe, new letters, then wax.
HalfTired
Heat gun to warm up the old adhesive and gently scrape away the old number witih a plastic tool to avoid new scratches in the Gel-coat.
Using a mild solvent (fingernail polish remover) worked really well for me when removing the glue residue, since most of it came off with just a little rubbing. By going only in one direction, I was able to roll it off like the rubber cement strips on your "junk mail" cards.
After that it was just wiping down with an alcohol pad to remove any reamaining residue and I was ready to apply the new hull numbers.
