Removing control box on 1992 Suntracker
I am having a fit here, will appreciate all help I can get! I have a 1992 Sun Tracker, 90ho Evenrude Pro, console mounted control box.
very tight quarters. I am trying to remove control box to replace throttle and shift cables. I have removed the set screw from inside the lever but I can not remove Lever. I am not sure how to remove neutral button at bottom of lever.
Any help out there?
alldodge
Most throttle controls require the handle to moved full forward so it can be removed. There is a bolt under the center button in most cases
