Working on this neglected locked-up motor for my brother in law. Lower spark plug was seized to head but came loose after 1 week soak with various penetrants. Much to my surprise the Thermostat Cover came off easily, although Thermostat is missing! Also surprised 8 of 10 Head Bolts came loose easily, 2 required soak for 2weeks but are now loosened/removed. Head is stuck to Block. There is a Gasket but doesnt appear to be any Gasket Compound or Sealant holding up disassembly. In the past on other motors i have been able to remove stuck Heads using a twisting motion with my bare hands. Not successful thus far. I am thinking to put 2 wooden dowels in 2 holes (opposite sides of Head) then laying a steel rod across the Head to get a stronger twisting motion that i can exert with my bare hands. I have also used sharp wood chisels in past to start separation, but this often causes slight damage thai has to be surface-ground out.
Anybody know any good tips on this problem of separating Head/Gasket/Block?
