After finging out that there is no compression in 2 cylinders I want to remove head to inspect valves, pistons, cylinders, etc. <br /><br />I need to take the cylinder head off (one side only). <br />Correct me if I'm wrong:<br />1) Drain exhaust manifold<br />2) Remove riser elbow<br />3) Remove exhaust manifold<br />4) Remove carburetor<br />5) Remove intake manifold<br />6) Remove valve cover<br />7) Remove head cylinder bolts and pull head<br /><br />Am I forgetting something?<br /><br />Thank you.
