Re: Removing heavy scale from water jackets
As a chemist I would urge some caution in the use of hydrochloric acid (aka muriatic acid) For calcium carbonate scale I would prefer to use a sulphamic acid** based descaler, sulphamic acid being a weaker acid than hydrochloric acid. In the UK we have sulphamic acid based central heating boiler descalers that can be used.
Organic acids, eg citric acid, are probably too weak to be a realistic option as the reaction rate will be very slow unless used hot.
AN alternative is Rydlyme see
http://www.rydlyme.com/home.html non hazardous and biodegradable they say!
If you must use hydrochloric acid I suggest a dilution of 1 part of the concentrated acid in 5 to 10 parts water, 1 in 20 for light scaling. ( the concentrated acid is only a 30 something percent solution of HCl in water)
** Sulphamic acid , I guess spelled sulfamic acid in the US, not to be confused with sulphuric (sulfuric ) acid as use in lead acid batteries.
Goggles and gloves whatever you use. Sodium bicarbonate handy to neutralise any splashes on the skin.
