How do you remove the lower unit to replace the water pump on 2 hp Johnson outboard.
T traveldog Recruit Joined Oct 9, 2009 Messages 1 Oct 9, 2009 #1 How do you remove the lower unit to replace the water pump on 2 hp Johnson outboard.
F F_R Supreme Mariner Joined Jul 7, 2006 Messages 28,226 Oct 9, 2009 #2 Re: Removing lower unit on 2hp Johnson out board traveldog said: How do you remove the lower unit to replace the water pump on 2 hp Johnson outboard. Click to expand... Hard to answer absolutely without knowing what year it is, but generally it is a simple matter of removing the two bolts and pull it off.
