Re: Removing Lower Unit
From the manual:
1. Remove (and isolate) spark plug leads from spark plugs.
2. Shift engine into forward gear.
3. Tilt engine to full “Up” position.
4. Remove 4 bolts and washers, two from each side.
5. Remove trim tab.
6. Remove locknut and washer in trim tab recess.
7. Remove gear housing.
The shift shafts are splined together and will separate as you lower the LU.
What is your engine s/n?
If you would like a copy of the manual. send me a PM with an email address and I will forward it to you.
Gerry
