Removing melted/burned rubber hose on Riser...
chrisf695
Can anyone suggest how to remove melted rubber hose from a stainless riser? I scraped most of it off... but still having some trouble.
Re: Removing melted/burned rubber hose on Riser...
Ayuh,..... Emery cloth,....
oldjeep
Wire or nylon wheel on a drill
dingbat
Solvents used to dissolve rubber:
• Toluene
• Methyl Ethyl Ketone
• Acetone
• Hexane
• Methyl isobutyl Ketone
chrisf695
Right on, thanks guys. Ill give those idea a try.
JoLin
• Toluene
• Acetone
• Hexane
What dingbat said. I used acetone to remove the residue of a burnt impeller from the water pump housing. Came right off.
