Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Are there more than 6 bolts holding the power pack onto the leg casing.I have removed the underneath 6 bolts screwed into the power pack but it wont budge off the drive unit, Any help appreciated.<br />Thanks
you mean powerhead <br /> most the time a power pack is a refernce to an ign component. my manaul only shows 6 bolts on the 2cyl 2 cycle 30 hp. the gasket will hold it pretty tight.
Yes it was only the gasket holding the power head on.I left it in the sun all day & just tapped it & off she came.I now need a bearing puller to remove the flywheel to get to the 2 bolts still holding the block to the lower sump.
