Removing Number Decals
mailman55
Hi, I just got my boat home that I had bought out of state and need to remove the Registration No's. The problem is they are foil backed and don't want to peel off very easy. Was wondering if there is a method that I have missed in removing them without hurting the paint? Any ideas? Thanks S Otte:confused:
Re: Removing Number Decals
Ayuh,............
An Industrial Strength Hair Dryer will Help,.......
Then clean up the adhesive with Acetone.........
mailman55
How about using a heat gun on say the lower setting?
bjcsc
heat gun = industrial strength hair dryer...
mystro
Ayuh,............
I've now got an aluminum boat with pearl paint, acetone might do
damage at least strip off the clear coat wouldn't it? There must be
a milder adhesive remover out there?
bomar76
WD-40
About the only thing on earth that junk is suited for.
