Removing outdrive / engine problems
Damfa
Hi everyone!<br /><br />I have to take out a totaly rusted AQ170 on a 280 outdrive, but it won't go out. It seems that the main shaft which goes to the u-joint is rusted together to the flywheel or something.<br /><br />The engine is hanging on chains, the upper gear unit (almost) disasembled, everything is loosen,... <br /><br />So, what can I do now? Do I have to cut the bell housing? This would be a pretty big problem since the 280 good condition (I plan to use it further).<br /><br />Any help would be appreciated.<br /><br />Damfa<br />Zagreb, Croatia
