Removing pine pitch from car paint
lakelover
My wife parks in a parking lot at work that is surrounded by pine trees and there really isn't any place to park that's not under the trees. I noticed some pitch on the car in a few places that had dried and gotten hard.
I tried to remove it with vegetable oil, and then turpentine - no luck.
How do you remove pine pitch without dissolving the paint?
dingbat
Re: Removing pine pitch from car paint
Finger nail polsih remover
Ayuh,.... Rub it with Butter....
real Butter, not oleo...
Bob_VT
I have had excellent luck with brake parts cleaner or carb cleaner......sprayed onto a paper towel and rub the pitch away. My wife works at an office and parks under a pine tree all the time and during the hotter weather it really drips. Just did her Toyota yesterday.
ehenry
We have lots of pines around here. I've found that brake parts cleaner works as good as anything.
rivermouse
Has anyone tried to freeze it and then chip it off?
Bob_VT
Nice idea but it does not remove it very well....... take that from a person who lives where it really freezes in the winter and the parts cleaner still works best.
Fishing Dude too
Spray with silicone let set spray again then it slides off after several sprayings
bruceb58
I would not be using acetone on car paint and that is what finger nail polish is.
lakelover
I have to admit, that one made me a little nervous and I'm going to try some of the others first. At any rate, I got lots of iedas to try, thanks everybody. I'll post back & let you know what I used. (The car is back at work parked under the trees as I write this, I'll probably have more to deal with now :facepalm:). It will be an ongoing battle.
ehenry
I'm tying to be a smart@$$ here but Bob_VT is correct. I use brake parts cleaner or carb cleaner just like he says on my 67 Chevell. The car has a true black lacquer paint job and those has never affected the paint at all.
Tim Frank
Turpentine works well, and is pretty gentle by comparison to some other options.
I use bug and tar remover. then I wax the snot out of the car a few times to prevent sap from sticking in the future.
denatured alcohol and WD-40 work well to remove sap. soak a cotton ball or a few sheets of paper towel and place over the sap, put something over it to hold in place for a few hours. come back and wipe clean with the alcohol. then spot-wax the area to protect the paint.
hungupthespikes
Master Chief Petty Officer
Been fighting the same problem for over 30 years.
http://googone.com
If it's dry then your SOL, and will have to use something that will attack the paint.
Like Scott said "I wax the snot out of the car a few times to prevent sap from sticking in the future."
lakelover
I tried turpentine, but it didn't work too well on the dried, hard stuff. It was just before she was leaving for work and maybe I wasn't patient enough. Today's the day I can work on it.
When I was a kid, my cousin and I used to use sticks to burst the pitch bubbles on spruce trees. We'd come home with the stuff, and an added layer of dirt, all over our faces and hands. My father would get out his can of turpentine and a rag, and scrub us raw until it was all removed and we stunk to high heaven. Good excuse for a couple kids to go jump in the lake! Fond memory! :) (I still like the smell of it!)
dingbat
There is a huge difference between finger nail polish and the advanced one and two-component polyurethane clear coats in use today.
Here are some of the performance specs for a common OEM clear coat
? ASTM D4752 MEK resistance: Greater than 1500
? ASTM D1308 chemical spot resistance: no effect
? ASTM D1308 skydrol immersion (7 days): no effect
Wiping the surface with a rag saturated with a product designed for use in contact with human skin isn't going to phase this stuff. I've been using finger nail polish remover for years and it doesn't bother the finish one bit.
