I posted recently about my 89' evinrude 140 having problems. It has good compression but was running rough at lower rpm's until it was pretty unusable at the end of last season. I cleaned the carbs, got it running and ready for the summer, then started going through everything since while much better it still was coughing. At low rpms you can barely notice, but between 1500 and low 2000 range I found a small leak in the gasket between the powerhead and midsection. I just ordered the gaskets for the midsection and things seem pretty straight foward about what to do. My question is what's the best way to remove the powerhead without pulling the flywheel, stator, etc..?
I prefer not to buy the attatchment piece or tools needed to pull the flywheel, the head weighs around 300 lbs though. Any advise on this or tips on redoing the midsection would be appreciated.
