removing prop
bert-nc
I need to remove the prop from a 1992 40hp Johnson outboard this week-end.
however, the trailer for the boat is away at another location.
will it cause a problem if I remove the prop while the boat is still in the water?
bert-nc
DAN M VAGOS
Re: removing prop
I have changed prop wile in the water just don't drop anything lol
steelespike
Re: removing prop
Bring the boat into shallow water; you might even be able to beach it stern first with the motor up.
Shallow water sandy bottom will make it easier if you drop the little bits.
bert-nc
Re: removing prop
thanks for the info, good advice concerning dropping parts or tools.
