Removing Seals in the Upper GearCase Lower portion
barko
Hi,
My boat is a Bowrider 1977 FiberGlass 18'
Engine is Mercruiser 470
Sterndrive is a MC-1 (Pre-ALpha)
This time I'm servicing my stern drive (Upper Gear Case Unit) by myself and I have the part kits and tools.
I'm done replacing and has no problem doing the seals where the U-joint portion is.
The part that I'm worried is the removal of seals in the lower portion of the upper gear case. I'm wondering if somebody could share their techniques/way/approach in removing the 2 seals.
Thank you.
flipbro
Master Chief Petty Officer
Re: Removing Seals in the Upper GearCase Lower portion
Its simple a long screw driver and a hammer! Flip the housing upside down Knock out the big one first! then flip it back over and Knock out the small one. Clean the casing apply blue loctit and reinstall both lips face up. Go to the adults only follow the links to the manual for your drive its a must
barko
Thanks a lot flipbro for your insight appreciate it!
Did you also do the installation of the new seal?
If yes, I would love to hear it how you did it and what improvised tools you use (if any).
Cheers!
Bt Doctur
I have made mine out of some steel stock but you can use a long 1/2 drive extention and install the correct size socket "backwards" to act as a driver
flipbro
I also did as Bt Doctur With socket and extentions works great!! Just find your manual in the stickies and follow it. Best advice i can give! And yes ive done the job a few times Just recently rebuilt my hole leg Had a pile of speacial tools to buy to do it ! In the long run a sei would have been cheaper but i will get more satisfation this way. Cheers And Good luck
barko
Hi Bt Doctur & flipbro, thanks a lot to your suggestions and tips. It works for me.
Cheers!
flipbro
Your Welcome
