removing seat back rest?
mainejohn
I have a 1990 Maxium 17 ski boat. How do i remove the padded back rests that are long the inside of the boat? i cant feel any bolts or screws on the back side! please help thanks
mainejohn
Re: removing seat back rest?
nobody knows? any help would be good
Bob_VT
Post a picture and that would probably help with advice.
mainejohn
yes the coaming bolsters look correct. i have read that some are screw from the back but i cant feel any screw or bolts. So i guess i just lift up on them and they should come out? Is this correct?
Ayuh,... Possibly...
or,..
If there's any "Buttons" on 'em, they Could be hiding screws...
ocimad27
Here are some pictures of how mine came off. There are plugs with compression fins on them. There were also two through bolts at the extreme front edge towards the bow. All the rest were compression plugs. Hope this helps
oops!
get your fingers behind there ans pull.
most just pull off
mainejohn
okay i will try this. so most are pushed in, not slid on those clips.
