Removing Start Solenoid on 5.7L Mercruiser
cbjones10
I have troubleshot down to proving I have a bad start solenoid, removed the 5 cables but can't figure out what holds it on. A trip to my local NAPA store reviewing a typical auto starter for a 1996 Chevy 5.7L engine didn't help. This solenoid doesn't have the two tabs with the small bolts so far as I can feel or see. The space is typical of a marine installation. You can't see 360 degrees and are lucky just to be able to get a flashlight in to see where it is. The boat is a 1996, 20ft Starcraft bowrider with 5.7L, V8 engine and 4 barrel carb. I'd appreciate any feedback. My nearby marine dealer was no assistance and there is a two week waiting line to get them to work on it. Thanks - Charlie Jones cbjones10@aol.com
snapperbait
Re: Removing Start Solenoid on 5.7L Mercruiser
Charlie.. My experience is that it's best to remove the starter from the engine and replace the soleniod on the workbench...
cbjones10
Thanks snapperbait. You are ever so right. I finally got enough of the back seat, etc. removed to feel what was present. The screw that has to be removed is backed up against the flywheel housing. I wish the marine design engineers were required to remove and replace some of these parts. They may be a little more sympathic to us do-it-yourselfs and mechanics. I figure it is going to take me several days fumbling and screaming to take care of this problem now that I have seen what has to be removed and replaced beside the solenoid.
