84 115johnson newbe
- Jul 22, 2013
- 31
I have a leaky seal, and haven't a clue on removing the gear case. I see 4 bolts in front + 1 bolt in the rear on a small block. Don't know what to expect next, or if I should have engine tilted or not ?.... Is the shift rod and drive shaft going to be a surprise? I work in maintenance, but have never changed a plug on an outboard.... "DUH"? 84 Johnson 115hp.
