Removing the primary shaft on 1994 Seasport 7.4 liter GM serial # 4110104354
JJWelch
I am in the process of removing the engine from the boat. Have taken the stern drive off and am unable to get the primary shaft out. What is the procedure?
You pull the 6 bolts off the clamp ring. And use 3 of the screws to drive the clamp ring off
Unbolt the lag bolts
remove motor and PDS housing as unit
