glenmoore670
- Apr 1, 2007
- 2
I bought a fishing rig with a Johnson 50 (J50BELCDE) a few years ago and was told by the previous
owner that the oil injection had been removed and that I needed to add outboard oil to the gas,
which Ive always done.
When I started it for the first time this season, I noticed a really strong gas smell. I removed
the cover and found a leak on what I thought was the fuel pump. However, a little research tells
me that it's the VRO pump. It's mounted on the air intake, has 3 hoses, and a 3-wire plug.
Since I've been mixing the gas anyway for several years, I'd like to just eliminate the VRO
system completely. I know I can cap off the two small hoses that go to each intake (?), and get
rid of the solenoid (?) that they come from. But I have a few more questions.
I don't know if the VRO pump regulates fuel pressure, or if the fuel line feeding it is already
regulated. I also need to know if I'll have to jump any wires on either the VRO pump harness, or
the solenoid that the oil lines connect to harness, in order for the ignition to work.
If there is anything else, or if someone could point me in the right direction I would really
appreciate it. Although I'm not an outboard mechanic by any stretch, I have been tinkering with
boats, bikes, cars, ATVs, and other engines for 25 years, so I'm not about to let this minor
problem stump me.
Thanks in advance!
problem stump me.
Thanks in advance!
