67/68 thunderbolt ign. #2119719<br />I am having trouble with my pee pee!
<br />Impeller is new and working fine. However when I force water through water pick up tube in lower unit, it will soon return out of the bottom but does not pee. I had found that prev owner had pinched the rubber between the head and the lower cowel but after removing, still no water. I wanted to see if the thermostat housing was clogged. nothing will happen either trying to flush from the pee end. I tried letting the engine warm enough to open thrmostat and still nothing. I did notice that the water coming out of the prop was definitly warm though. <br />I want to take out the thermostat but seems like lower cowel is in the way. do i need to remove it? is it difficult or does it simply drop down?<br />Thanks as usual!
