crazy charlie
- May 22, 2003
- 5,602
Ongoing problem. Twin 5.0xl Mercruiser i/os with alphas.Checked and changed just about everything associated with it.Mani,risers,impeller etc.,tstat,t-balls.Started out season fine and temp slowly began to rise again .Only at idle and more recently when coming off plane.Usually a tap up on throttle of 2000 rpms brings down the temp .I pulled the tstat today in attempt to isolate the problem.I am about to order a new tstat housing.Don sent me some good info on the housing and it appears I have the correct one on.I plan on running the boat a day or two w/o the stat and possibly remove the t-balls next.I assume this is safe as long as I dont leave it that way..?? It has been a long process of elimination.Charlie
