dingbat
- Nov 20, 2001
- 16,469
Im currently running 22 Grady W/A with a hardtop, the whole bit using a 14 x 17 Renegade Offshore prop on a 1997- 200 hp Ocean Pro. The WOT with the Renegade is only 5000- 5100 but the speed (35-36 mph) seems reasonable to me considering the weigh of the boat and that Im only running 5000 rpm.
Ive been told that this motor should be running mid- to upper 5K rpm so I have a stock Envinrude 15 x 17 aluminum prop I want to try. Will the aluminum prop make that much difference in my rpm or should I be looking at something else? It looks like I could raise the motor up a hole if I had too but Id prefer not to unless I need to.
