Reoccuring stator failure 90hp inline 6
squawman
The motor started dropping cylinders, 2, 4 and 6. While testing the stator, It passed all the test but one (blue/white, red/white, 5400/6200 ohms)the leads run to the switchbox for cyl. 2,4 & 6. I replaced the stator and the rectifier. The boat ran great. the 3rd trip out I noticed that the tach was stuck at 5100 rpm but the motor seemed to run fine accept for the motor sputtered a few times. Then while plaining the motor sputtered one more time and dropped 3 cyl. as before except it was now 1, 3 and 5 While testing the stator, It passed all the test but one (blue, red, 5400/6200 ohms)the leads run to the switchbox for cyl. 1,3 & 5. <br /><br />Test made with a Goldstar DM9183<br /><br />List of readings:<br />Stator ohms<br /> 20k scale red to blue = open /should read (5400/6200 ohms at R* 1000)<br /> 20k scale red/white to blue/white = 5.84 /should read (5400/6200 ohms at R* 1000) <br /> 200 scale red to GRD. = 145.0 ohms /should read (125/175 ohms at R* 1)<br /> 200 scale red/white to GRD. = 145.0 /should read (125/175 ohms at R* 1)<br /> 20k scale Yellow1 to GRD = open<br /> 20k scale Yellow2 to GRD = open<br /> 200 scale Yellow1 to yellow2 = 1.1 /should read (less than 1 ohms at R* 1)<br /><br />Stator volts at 1500 rpm<br /> Blue to GRD. = 27 vac <br /> Red to GRD. = 50 vac<br /> Blue/white to GRD. = 135 vac<br /> Red/white to GRD = 72 vac<br /> Yellow1 to GRD. = 9.25 vac<br /> Yellow2 to GRD = 9.25 vac<br /> Yellow1 to yellow2 = 17.2 vac<br /><br />Rectifier volts at 1500 rpm<br /> Red to GRD. = 17+ vdc (when starting volts drop to 8.5 vdc)<br /><br />There is a black/white wire that bridges the two switchboxes. I could not find this on my<br />wiring dia. ?<br />The miss is intermittent at low rpm and continuos at mid to high.<br />What could be taking out my stators ?
