Repair crack in hot tub
PuddleJumper
Got a used hot tub from brother in law. There is a crack in angle of the lounge seat. Don't know if it is thru and thru. Any good ideas to pre emptively seal it before I put water in?
flashback
Re: Repair crack in hot tub
Hi Deej, assumeing this is a fibreglass tub, you would repair the crack in the same fashion as repairing a boat.. If it is thru and thru, then you need to glass both sides, If it is just in the gelcoat, then carefully dremel the crack into a shallow "v" and fill it with some marine tex or equivilant filler..
