Re: Repair leak under rub strake?
i ended up patching over lapping the bottom of the strake (the bit thats nearly flat to the pontoon) and 40mm of the pontoon and about 80mm wide. i realise its not ideal as there is a 1mm difference between the pvc and the rubber pontoon, but i pressed it in made sure there was enough glue in this area. so far so good, ill do it differently next time. somebody mentioned because the leak is only a pinhole i could have just used the bonding glue to seal it, not sure how effective that would have been.
