mike64
- Apr 10, 2008
- 1,042
My prop is a little chewed up. It seemed to push the boat ok last summer but I don't know how much better performance I should get. I have a '72 rude 65 hp on a 16' v-hull fiberglass runabout that weighs about 1000 lb. The dia. & pitch reading on the prop looks like 13-1/4" x 17. Does it need repairing? Is it almost as expensive to repair, so I might as well replace it?
With just me, on calm water I top out at 30 mph. No tach, I don't know my max rpms. The motor has good compression, around 130 on all cylinders, seems to run like a champ. Should I expect to get more speed? Is a 13-1/4" x 17 prop the best configuration for my boat/motor?
