repair power supply to Johnson50hp
Status
Not open for further replies.
ofishlbusiness
not getting power to motor, battery ok<br />where do I connect negitive and positive<br />to ground the battery.
suzukidave
Re: repair power supply to Johnson50hp
if you want someone to take the time to help you, you should at least take the time to type out a comprehensible message.
flyingscott
+ (red) goes to the starter solenoid. - (negative) goes to the block probably a stud on the exhaust cover.
Status
