Repairing brass
llfish
Not sure this is brass but it looks like it. I would say it is made out of the same material that those long twist nozzles for garden hoses. I overtightened a drain plug on the in-feed side of my 3500 pressure washer. Well I cracked the housing. Is there a way to repair it other than buying a new housing?<br /><br />Thanks for the help in advance
Bob_VT
Re: Repairing brass
JB Weld is supposed to work on brass.... and considering that this is the "low pressure" side it might work. If it was my choice I would replace the bad part and be done with it. <br /><br />Doing it right the first time beats doing it twice.<br /><br />Bob
llfish
Re: Repairing brass
You do not know how many times I tell my self that. But for some reason I have to find a short cut whit the intention of doing it right when winter comes.
JB
Re: Repairing brass
Brass solders quite well. Need a propane torch and solder (flux, too).
llfish
Re: Repairing brass
Thanks for the information JB and Bob
jlshields
Re: Repairing brass
Take it to a welding shop or anyone with a torch and ask them to braze it. That's brass!
neumanns
Re: Repairing brass
Call the manufacturer...you might be pleasantly suprised. If not then consider the repair. It is somtimes amazing how nice and generous the manufacturers can be...It is worth a call.
llfish
Re: Repairing brass
The Manufacture has gone out of business. But probable take it to a welding shop.<br /><br />Thanks everyone for the help.<br /><br />Larry
Re: Repairing brass
Like Bob_VT said this is low end (pressure wise) of the system. JB Weld, Marine Tex.. solder or have it brazed. All easy and cheap. I tend to go for over kill and would have it brazed.. <br />My .02 worth.. <br />3 bucks for JB Weld and five bucks for Marine tex.. or formular 27 and 30 bucks to have it brazed... I would still have it brazed.. <br />Did I say Over Kill!<br />Link :)
