I just got done painting my fiberglass boat, while painting i had it sitting on 4 4x4 posts. one of the posts broke the hull some.
if you could picture the outline of a 4x4 post on a boat, half of that broke through.
my plan is to cut out the damage so it doesnt crack further, then sand the area around the hole just to rough it up. then start with small pieces of fiberglass mat, and slowly get larger and larger pieces. and make the repair area atleast 3 times the size of the damage and make sure i apply a bunch of layers, so it will be strong (and ugly, but dont care)
i dont care what it looks like as its the bottom of an old boat, i just want it to be safe, waterproof, and strong.
will this be a suitable method? i know it would be better to go from the backside but that would require me cutting a hole in the floor of the boat, then repairing that hole which is counterproductive especially when i dont care how the bottom of the boat looks.
also what is wrong with using polyester resin as compared to epoxy?
the resin says on the bottle, safe for all applications including boats, and 100% waterproof. I already have a gallon of polyester resin so i would like to use it if its possible.
