Reparing a side window in a car
Tyme2fish
Sister-in-law was ready to leave our house with a thunder storm trying to form up. Her driver's side electric window would not roll up.
I'm not enough of a mechanic to tear her door panel out and fix her problem so I did the next best thing.
Plastic drop cloth and duct tape.:facepalm:
Bob_VT
Re: Reparing a side window in a car
STEP ONE Check the window LOCK and see if it has been activated.
angus63
Step2 keep up button depressed while slamming door closed.
Bob_VT
Step 3 Kiss the SIL on the cheek and remind her to drive careful! ;)
puddle jumper
Wile pushing on the up button move the wiring harness in the door jam. Its common the wires to brake in the harness there.
rivermouse
Only thing I can add is if you try to fix it DONT stick your hand into the door with the panel removed unless the battery is disconnected. A good way to lose your hand or fingers.
delirious
i have taken off inner door panels and got power windows to go up using a battery frm a cordless drill dirrectly on the motor...only works if its a switch or wiring issue...screewed if its a motor issue
dolluper
duct tape and plastic you got it done ....the pros will finish ....you did what you could .....thanks bro sis said EH
Tyme2fish
Exactly. I just noticed I can't spell. Repairing. See I can spell it correctly!!!!
